Replacing Gutters When Replacing Roof
March 29, 2022 at 7:37 a.m.
When replacing a roof, is it best to also replace the gutters at the same time? Do gutters need replaced?
March 29, 2022 at 7:38 a.m.
It is not necessary to replace gutters at the time of installation of a new roof.   The life of the gutters is determined by the Quality of the gutters and the abuse they have suffered.
If you have “built in” gutters (in other words, the gutters are installed within the fascia and starter board): At the time the roof is removed to install the new roof is an excellent time to replace the gutters if an inspection shows signs of deterioration.  Generally, the gutters will outlive the roof.
If the gutters are conventional sheet metal with standard hangars, they can be replaced at any time quite easily.  At the time of installing the new roof, the gutters can be inspected and repaired as necessary or replaced.
Keep the gutters in mind as you do standard maintenance on your house.  Keep the gutters clean and free of trash, leaves and debris.  Paint the gutters as you paint the fascia with a good quality exterior paint.  You will be rewarded with gutters that will give you many years of satisfactory service.
Regards,
Your Friends at AskARoofer
April 10, 2022 at 9:50 p.m.
Darrel EM
When planning to install a new roof it's better to replace the gutters with a new one. The new roof material and the gutters create a new appearance to the home. Also, it is difficult to find the roof colour shingles that match the existing gutters. I have recently renovated my home roofing with grey slate tile and also installed the gutters that match the colour of the slate tile
