How many layers of shingles?
February 17, 2022 at 11:55 a.m.
How many layers of shingles are pictured? Several companies told us one layer on an estimate bid. Now once signing we are told there is a second layer of tear off. I'm having trouble seeing it as two layers though. Any help is appreciated.
February 17, 2022 at 11:59 a.m.
Wendy Marvin from Matrix Roofing and Home Solutions had to say in response to your question:
It’s very difficult to tell from a single photo.  This appears to be showing one layer of shingles. However, what often happens is that a second layer can be “cut back” to only be found further up in the roof?  Perhaps a video while the roofer is inspecting is in order?
Adding a 2nd layer to tear off and disposal is a hefty additional cost to the homeowner.  The roofer should be willing to document via picture or video, why they believe there is a second layer.
Hope this helps!
Wendy
200 @ forum_topic_master
HTTP status 200 OK
Route name forum_topic_master
Has session yes
Stateless Check no
Time 903 ms
Total time 903 ms
Initialization time 156 ms
Memory 44.0 MiB
Peak memory usage 44.0 MiB
PHP memory limit 2048 MiB
2
2 AJAX requests (Clear)
# Profile Method Type Status URL Time
1449141POSTxhr200/ajax/content-impressions1255 ms
26820c2POSTxhr200/ajax/mitem-impressions920 ms
Logger 231
Errors 0
Warnings 0
Deprecations 231
Cache 1802 in 201.03 ms
Cache Calls 1802
Total time 201.03 ms
Cache hits 1782 / 1792 (99.44%)
Cache writes 10
Security n/a
Authenticated No
Firewall name main
Twig 189 ms
Render Time 189 ms
Template Calls 40
Block Calls 16
Macro Calls 0
70 in 44.03 ms
Database Queries 70
Different statements 26
Query time 44.03 ms
Invalid entities 0
Second Level Cache disabled
0
Real Blocks 0
Containers 0
Events 0
6.4.10
Profiler token 1d7cf1
Environment dev
Debug enabled
PHP version 8.1.31   View phpinfo()
PHP Extensions Xdebug ✗ APCu ✗ OPcache ✓
PHP SAPI fpm-fcgi
